RAM usage limit under Windows 64bit / ICEM
Old   December 1, 2006, 08:53
Default RAM usage limit under Windows 64bit / ICEM
flga
I use ICEM now in a Windows XP 32bit system with 2GB RAM, but the computer is 64bit capable.
Under Windows XP 32bit the maximum size of a single process is 2GB, but the "theoretical" limit of a 32bit aplication is 4GB.
My question is: if I execute ICEM 32bit under Windows XP 64bit, can ICEM use more than 2GB of RAM?
Thanks in advance,
flga
Old   December 1, 2006, 16:11
Default Re: RAM usage limit under Windows 64bit / ICEM
fea user
My opinion is...yes. I didnt try it, but I think. In a 64bit system the biggest advantage is the memory usage. You can use more physical and more virtual memory. Now I use 4 Gb phys. RAMs and 14 Gb virtual memory in my 64 bit system. My largest memory usage was approx. 6 Gb memory with workbench, and in other case CFX 10.0...in both case I've used 32bit version of these softwares. Workbench has 64bit official version. Now all softwares goes to the 64bit's most powerfull way! This is only the way, to handle large models and difficult processes on single workstation (if you havent got clusters).
Old   December 5, 2006, 03:02
flga
Thanks, fea user. I will give it a try!
Estimation for memory usage by ICEM ftab Hardware 5 September 19, 2011 04:32
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
[ICEM] ICEM windows disappears val17lr ANSYS Meshing & Geometry 2 May 31, 2010 22:09
using more than 2GB RAM on a windows PC Raju Main CFD Forum 10 October 22, 2006 03:29
CFX and windows 64bit CFDworker CFX 6 September 5, 2006 21:46
