Define an equation for the inlet velocity profile
Old   January 9, 2007, 01:14
Default Define an equation for the inlet velocity profile
Alshroof
Dear CFX guys; I am trying to define an equation for the 2D inlet velocity profile. I am defined two equations for the vertical coordinate where I'd like to divide the vertical coordinate to two stages, since i have for each segment different equation.
I wrote the equation using the CEL function but my problem is how to tell the CFX function to use equation 1 for the 1st segment and equation 2 for the other. for instance from 0<y<1 i need it to read equation 1. and from 1<y<10 to read equation 2.
Old   January 9, 2007, 03:33
Default Re: Define an equation for the inlet velocity prof
Michael B
Use step function. The step function is used as an example in the documentation to set the initial pressure in a water/air with sealevel case. Check that out.
Old   January 9, 2007, 17:59
Maryam
I have the same problem and tried to use the profile data, however till now I've not been able to set it correctly.
Old   January 9, 2007, 19:34
Osama
I solved my problem in different way, i generate two surfaces for the inlet and i defined an equation for each surface. Hope that will help.
(ask) how to create UDF for inlet velocity profile sincity Fluent UDF and Scheme Programming 83 May 16, 2022 13:04
patching velocity profile to the inlet face of domain vasuaero1988 Fluent UDF and Scheme Programming 1 September 29, 2010 03:49
FSI- Pipe- uniform velocity profile inlet Absy Main CFD Forum 0 April 6, 2010 03:01
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
