creating CFX mesh
Old   January 15, 2007, 18:25
Default creating CFX mesh
igor
I have a question concerning more ansys workbench v9 than CFX module.I have to simulate the 3D heat transfer among heating parts inside a box and internal-external walls through a fluid. I've created firstly a fluid as a solid element with FIll command, then I've frozen all the parts and with body operation->slice material created the intersection. Is it the proper way? Is there any difference between slice and cut material in frozen/unfrozen mode? and is it really necessary to freeze the parts? Then I exported the model in CFX-Mesh, having difficulties with volume generation: probably it depends on the complex geometry. I found only this notes on the help documentation. Is there a simpler way to simulate the presence of a fluid inside a box, without incurring in such intersection difficulties? The problem is also the asymmetry of the model I have to study. Thank you in advance! Eng. Igor Di Varano,Italy
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Creating a 2D Mesh using ICEM VSB CFX 0 November 1, 2006 22:17
[Other] Problem when trying to generate a new mesh gaottino OpenFOAM Meshing & Mesh Conversion 0 June 30, 2006 07:51
CFX mesh & ICEM mike CFX 3 April 27, 2006 15:27
