Mismatch nodes on periodic face>tolerance
Old   January 16, 2007, 21:54
Default Mismatch nodes on periodic face>tolerance
chotet
above is my problem after generating surface mesh.are there any problem if i still continue with the analysis if i have the above problem?will it be any problem occuring the solver later? thank you...
Old   January 18, 2007, 23:26
Default Re: Mismatch nodes on periodic face>tolerance
Johnny
You won't be able to use a 1:1 match for the periodic interface in CFX - you will need to use GGI.
Old   January 19, 2007, 08:37
Joe
Not so.
SIMPLE algorithm SamR Main CFD Forum 19 April 26, 2019 13:06
Symmetry and Periodic boundary conditions CFD_Fluent_User FLUENT 1 October 16, 2014 02:18
error: no periodic nodes on thread __. HELP !!! bne FLUENT 0 June 20, 2007 11:57
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
