CFX10 sp1 on EMT64 processors under 64 bit linux?
Old   February 2, 2007, 18:16
Default CFX10 sp1 on EMT64 processors under 64 bit linux?
Harold
Hi all,
We are thinking about changing our cluster from Opterons to Intel Clovertowns running RHEL 64 bit.
Has anyone else run CFX10 sp1 on EMT64 processors? Does it work???
Thanks!
Old   February 3, 2007, 02:32
Default Re: CFX10 sp1 on EMT64 processors under 64 bit lin
Charles
Yes
Yes
Old   February 3, 2007, 03:51
Harold
Excellent!
Any additional patching required or does vanilla CFX10 sp1 just work?
Old   February 3, 2007, 06:53
Charles
It's quite a while since I did this, but I can't remember any problems. What I have experienced is that not all CFD codes are immediately compatible with all Linux distributions. One answer is to use the version of Linux recommended by the CFD code vendor (normally not free), but I have also had luck just using Fedora Core 4 (free), with the single catch of having to install ALL packages from the distribution to ensure that the necessary libraries are installed.
Old   February 3, 2007, 10:52
Harold
We use RHEL which is officially supported.
What cpus did you do this for? Woodcrest, Clovertown, Xeon x3xxx ???
Old   February 3, 2007, 12:18
Charles
These were the older generation 3.6 GHz Xeons, the first ones with EM64T, i.e. single core chips.
Old   February 6, 2007, 20:40
HekLeR
You will need a non-released custom patch to run cfx 10 on this hardware, which is very new.
Talk to your service rep.
cfx 11 just works out of the box.
Old   February 8, 2007, 00:35
Harold
Ok will do.
Is this required for all EMT64 CPUs even the desktop Core2Duos or does it just apply to the never EMT64s e.g. Woodcrest/Clovertown???
Old   February 10, 2007, 15:37
HekLeR
I'm only aware of the problem on woodcrest and possibly clovertown.
ansys 11 under linux 64 bit mbn86 ANSYS 4 November 29, 2011 05:03
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 16:49
help or suggestion required -64 bit linux + gambit Ramesh.K FLUENT 2 October 20, 2008 14:14
star-cd with linux in 64 bit intel prs. Ruzi Siemens 8 March 15, 2007 04:57
Solver error with return code 137 (CFX10 in Linux) JamesH CFX 0 January 25, 2006 05:54
