CFX Error Message
Old   March 12, 2007, 07:22
Default CFX Error Message
lindsey
I trying to run a transient sloshing simulation in CFX 5.7, however I keep getting the following error:
Error detected by routine PEEKCS CDANAM = BCP3/VARIABLES/VEL_/BCTYPE CRESLT = NONE
ERROR #001100279 has occurred in subroutine ErrAction. Message: Stopped in routine MEMERR
Can anybody explain this please? I guess it is something relating to the velocity and boundary conditions. However, I have only a pressure outlet and initial velocities are all zero. Movement is initiated by harmonic oscillating sway accelerations though CEL Expressions.
Thanks Lindsey
Old   March 12, 2007, 08:38
Default Re: CFX Error Message
Joe
Your CEL expressions and/or routines contain an error. They are calling a non existent variable.
Old   March 12, 2007, 11:45
lindsey
Joe,
My expressions are as follows: CEL:
EXPRESSIONS:
DensityH = 998 [kg m^-3]
HydrostaticPressure = DensityH*g*VFH2O*(InitialHeight-y)
InitialHeight = -.071 [m]
VFAir = step((y-InitialHeight)/1[m])
VFH2O = 1-VFAir
XAmplitude = 0.01 [m]
XFrequency = 1 [s^-1]
XOmega = 2*pi*XFrequency
XSway = -XAmplitude*(XOmega^2)*sin(XOmega*t)
YSway = -g
END
CFX seems happy with them in pre, either returning a value or the plot that would otherwise be expected.
I have no routines running that I am aware of...?
Can you see an error in that?
Old   March 12, 2007, 16:17
The function calculating HydrostaticPressure calls the variables VFH2O and InitialHeight which are not defined but are defined later. Move the calculations of VFH2O and InitialHeight to before this line.
Regards, Glenn Horrocks
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 02:38
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
PhD using CFX Rui CFX 9 May 28, 2007 05:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
