March 14, 2007, 08:20 |
Droplet boundary layer
Any one know, how to simulate falling droplet on a vertical wall (boundary layer study + heat and mass transfer study) IN CFX 10
Regards |
March 14, 2007, 12:49 |
Re: Droplet boundary layer
Just getting the cold flow model right would require carefull validation against experimental data. Surface tension effects on real surfaces are notoriously finicky e.g. composition, contamination, roughness, ...
If you dont have good experimental data to validate against, you are going to have to do that first anyway, which may make using CFD redundant. |
[Gmsh] Default Faces on Boundary Layer | axel | OpenFOAM Meshing & Mesh Conversion | 8 | February 17, 2011 07:47 |
[GAMBIT] problems in boundary layer | yubaibai88 | ANSYS Meshing & Geometry | 8 | April 19, 2010 21:07 |
3D Boundary Layer | Mario | FLUENT | 0 | February 17, 2009 03:40 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
boundary layer thickness | 98.4F | Main CFD Forum | 1 | December 29, 2000 07:23 |
