March 20, 2007, 13:39 |
Negative Volumes in Wigley Hull ICEM CFD
Hi everyone,
Currently I am using using ICEM CFD to mesh a half wigley hull in a rectangular domain with a symmetry wall. I am splitting the block near to the Wigley and doing the association of vertices-points and edges-curves in order to match the blocking with the geometry. I am using several ways to mesh such as o-grid, surface mesh size or applying pre-mesh parameters by edges. But, always when I check quality mesh with determinant 3x3x3 there are negative volumes under the keel or near to the bottom part of the bow or the stern. How can I improve the meshing in order to correct that problem? Is the problem based either on the association step or in the blocking strategy? Thanks in advance, Carlos Andrés. |
March 21, 2007, 18:52 |
Re: Negative Volumes in Wigley Hull ICEM CFD
Dear Carlos Andrés,
I think there is problem in your geometry under the keel try to see the in the software where you modeled the wigley hull you might have some intersections or surface is not well defined so when you import into icemcfd it will degenerate the surface and thats why its giving negative volume error. regards, sam. |
March 1, 2010, 02:55 |
erhan
Rep Power: 17 |
hi
ı have similar problem what can ı do? |
How to fix negative volume elements in icem cfd? | shirish | CFX | 5 | June 5, 2018 01:59 |
Import Mesh from ICEM CFD to CFX | Andre Almeida | CFX | 16 | April 19, 2016 03:42 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
ICEM CFD Modules | Boris | FLUENT | 1 | March 12, 2004 14:37 |
