transient time step
Old   March 29, 2007, 14:16
Default transient time step
new user
For any transient problem, what is the right way to decide a timestep?
I ran a particular case with time steps of .01,.001,.0001,.00001.
As I plot the change in velocity at a point, with respect to time. All the plots for various timesteps don't overlap. Isn't it true that to have my solution timestep independent, my plots with various timesteps should overlap? Should I keep going to a smaller timestep? But I don't have forever to solve my problem.
I searched through all of the forum, but couldn't get a correct answer to my problem.
Thank You
Old   March 29, 2007, 14:43
Default Re: transient time step
Joe
Search the help file for "courant number"
Obtaining mesh/timestep independent results depends on many factors including both spatial and temporal resolution. Using ultrafine timesteps on a coarse mesh isnt going to gain you much.
Old   March 30, 2007, 18:23
new user
Thanks Joe!
I know what you mean. I been through the courant number related posts, before I posted the question
And I understand from the post that if convergence isn't a problem within a timestep ( i reach to residuals of about E-6) , courant number is not important, since CFX is an implicit solver. And explicit solvers would require Courant numbers less than 1.Is this understanding flawed?
But anyway, a timestep of E-3 gives me a courant number equal to 5, and E-4 gets me something below 1.
I also realise that my solutions are almost the same with different timesteps. They are just out of phase. I have a paper that claims a transient result like that is good enough to show timestep independence, because the difference in phase is because the vortices are resolved differently in each case.Is this correct?
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 12:50
directMapped problem panda60 OpenFOAM Bugs 4 July 8, 2010 10:23
Time step in transient simulation shib FLUENT 0 June 17, 2010 13:07
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
