May 23, 2007, 17:51 |
folded mesh in FSI
I am simulating a static FSI problem over a fixed wing in transonic flow regime. The problem which arises is related to the remeshing of the boundary-layer mesh, which in my case is quite fine (low y+). I have tested various values of mesh stiffness and model exponent, via the three available methods in CFX, without any result. I am wondering any CEL expression related to the total mesh displacement would help?Did anyone test anything with success ? Thanks in Advance
May 23, 2007, 21:03 |
Re: folded mesh in FSI
Did you try reducing the exponent for the Increase Stiffness Near Walls setting? There is an upper limit for the stiffness, and sometimes using a large exponent forces the stiffness everywhere to hit this limit, resulting in a relative stiffness of unity. You can plot the mesh stiffness in Post to check.
May 24, 2007, 07:33 |
I tried to reduce the exponent to a value of 1 (minimum, while the default is 10, but no progress has been made!
Now i test a cel expression for the mesh stiffness value directly, which i enforce locally (large displacements) to increase the stifness.This expression in brief is: 1e+25*total mesh disp x*total mesh dip z +1e+9 Do you agree? (x and z are the main deformation directions) Have you ever used any cel for the stiffness with success? Thanks |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
FSI mesh stiffness help | realanony87 | Main CFD Forum | 2 | June 21, 2009 15:29 |
