June 20, 2007, 10:18 |
dynamic material properties
Hi everybody,
Is it possible to set material properties in CFX-Pre which are dependent from the current region/subdomain? I have following case: Air flows through a domain and in this domain is also a porous subdomain. I like to have a different orthotropic thermal conductivity for the air in the porous subdomain as in the rest of the domain. How can I implement it in CFX? Thanks a lot, Greg |
June 21, 2007, 10:53 |
Re: dynamic material properties
Hi Greg!
You can define your thermal conductivity using a CEL-variable. This can again depend on the subdomain via the CEL-Function inside. inside()@Subdomain_Name takes the value 1 in the subdomain Subdomain_Name and zero otherwise. Hope this helps. - Terje |
June 21, 2007, 11:33 |
Hi Terje!
Thanks a lot for your help, this CEL-Function is very helpful for my purposes. Greg |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Temperature-dependent material properties in chtMultiRegionFoam-Solver | sebonator | OpenFOAM | 0 | November 15, 2010 08:15 |
How to add more material properties | sarahsun | CFX | 1 | October 27, 2009 07:27 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
