dynamic material properties
Old   June 20, 2007, 10:18
Default dynamic material properties
Greg
Hi everybody,
Is it possible to set material properties in CFX-Pre which are dependent from the current region/subdomain?
I have following case:
Air flows through a domain and in this domain is also a porous subdomain. I like to have a different orthotropic thermal conductivity for the air in the porous subdomain as in the rest of the domain. How can I implement it in CFX?
Thanks a lot,
Greg
Old   June 21, 2007, 10:53
Default Re: dynamic material properties
Terje
Hi Greg!
You can define your thermal conductivity using a CEL-variable. This can again depend on the subdomain via the CEL-Function inside.
inside()@Subdomain_Name
takes the value 1 in the subdomain Subdomain_Name and zero otherwise.
Hope this helps.
- Terje
Old   June 21, 2007, 11:33
Greg
Hi Terje!
Thanks a lot for your help, this CEL-Function is very helpful for my purposes.
Greg
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Temperature-dependent material properties in chtMultiRegionFoam-Solver sebonator OpenFOAM 0 November 15, 2010 08:15
How to add more material properties sarahsun CFX 1 October 27, 2009 07:27
