Periodicity in CFX
Old   August 25, 2007, 22:25
Default Periodicity in CFX
Sam S
Hi there
I'm having some serious issues with using the periodicity function in CFX. The system I'm working on can usually handle standard 2D problems up to about 1,500,000 elements. However, I have recently moved to 3D and am working on a particular problem where a periodicity interface needs to be used. I am finding that even on course mesh problems with around 300,000 elements, the computer is returning an error saying "Insufficient Memory Allocated". If I remove the periodicity, this problem will solve, albeit incorrectly. Even after i have drastically increased swap space, I am still having this error. I know that CGI periodicity uses more CPU power and more memory, but this much? Does anyone have any suggestions? If so I would much appreciate any
Thank you very much,
Sam
Old   August 26, 2007, 18:35
Default Re: Periodicity in CFX
I use periodicity a fair bit and don't have the problem. I would check the periodic boundary is set up correctly, with faces parallel (if translational) or the rotation axis correct (if rotational).
Also - what physics are you using? Not all physics supports periodicity.
Old   August 27, 2007, 00:59
johnny
If your error states "Insufficient Memory Allocated", simply increase the memory allocation factor.
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
Periodicity of a function (loop) CFX uorinopuot CFX 2 October 27, 2009 19:15
PhD using CFX Rui CFX 9 May 28, 2007 05:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
