September 7, 2007, 09:32 |
Radiation modelling
Hi all,
Is there any way I can define a wall which can absorb the incoming radiation but no emission or reflection takes place? I want to model a radiation problem to calculate radiation energy transfer between hot and cold plates and also between hot plate and the outside environment. Right now I have two solid bodies immersed in a fluid domain and a part of radiation emitted by these bodies is reflected back by the fluid domain walls. I want to assign properties to fluid domain walls in a way they will not emit or reflect any radiation. I have tried emissivity as '0' but in that case there was no emission but all the incident radiation reflected back. I also tried emissivity '1' and room temperature boundary on fluid domain wall but still my results are not looking good. I appreciate your help. Deeps |
heat radiation modelling | chubb | STAR-CCM+ | 5 | March 20, 2010 17:39 |
Radiation modelling | Sally | CFX | 0 | September 3, 2008 11:00 |
Radiation modelling Surface-to-Surface V11 | TobiasZ | CFX | 1 | December 18, 2007 08:47 |
solar radiation modelling | PONDA | FLUENT | 0 | April 6, 2007 03:51 |
Questions about radiation modelling | Yingchun | CFX | 5 | November 23, 2005 01:53 |
