mesh motion tutorial error
Old   October 3, 2007, 10:52
Default mesh motion tutorial error
Virag Mishra
Hi Im trying to solve the tutorial 20 (the one involving motion of the ball inside the valve FSI problem) in CFX11 USING USER FORTRAN. The cfx5mkext command in command editor is fine and it is generating the required *.dll,*.exp,*.lib and *.obj files and im able to export the simulation even to solver BUT the the solver is not able to run the simulation after timesteping information; it just reads" An error has occurred in cfx5solve: | The ANSYS CFX solver could not be started, or exited with return code 255:No results file has been created.
The last job done by solver probable is this Reading mesh for map generation File read: <file path>\meshes\DefaultDomain.0 I guess the problem is that solver is unable to interpreat node cordinates in DefaultDomain.0
Any idea how to deal with this, its imp. Thanks in advance
Old   October 6, 2007, 07:08
Default Re: mesh motion tutorial error
Johnson
Could be a number of things.
What is the output in the terminal window?
Johnson
Old   October 6, 2007, 08:55
Virag Mishra
Probably the reason was some installation problem with VC++ or Intel fortran, Well I modified the cfx5mkext.ccl to suit the compaq compiler, its fine now. Thanks for response Johnson
polynomial thermophysical properties II sebastian OpenFOAM Running, Solving & CFD 54 November 21, 2019 07:12
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
