Developing Hydrodynamic Layer
Old   October 11, 2007, 09:56
Default Developing Hydrodynamic Layer
selim
Hallo,
I am performing a transient CFD with parabolic velocity for the steady part of inlet velocity and rectangular profile sinusoidal for fluctating part of the velocity at the inlet.
I see at some distance later the change in the x direction is zero.(Fine) But what I need is exactly the change in x-direction =0 as close as to the inlet(say 4-5 cells later) I forgot to say, this is also a heat transfer problem with a partion of the channel is heated at the upstream close to the inlet.
Is there a way to make x-direction changes (streamwise direction I mean by x) 0 starting from the inlet in an unsteady run?
Thanks in advance, Selim
[snappyHexMesh] SnappyHexMesh - no layer added bejbro OpenFOAM Meshing & Mesh Conversion 5 February 1, 2020 20:05
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
Spatially Developing Turbulent Boundary Layer Inlet deji OpenFOAM 1 June 8, 2010 14:52
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
