BladeGen problem
Like Tree1Likes
  • 1 Post By pankaj
Old   November 7, 2007, 03:25
Default BladeGen problem
David Wang
Hi:
I have two question about BladeGen software.My version is V11.0. The one question, does BladeGen can deal with propeller geometric model which used in ship? I can't find out any information in help files.
Another question, when I use the Data Import Wizard Guide, it told me not find bgImport.hlp files. Where can I get it?
In addition, is this version v11.0? In What's New table , it shows as below:
"BladeGen 10.0 incorporates the following new features:
Licensing
BladeGen now uses the ANSYS Licensing Manager.
TurboGrid Export
Additional information is provided to TurboGrid about the blade (e.g. units and leading and trailing edge types) to minimize user input when preparing a mesh in TurboGrid (Version 10.0 or later.)"
Sincerely
Old   November 7, 2007, 07:24
Default Re: BladeGen problem
Pankaj
HI David!
With Bladegenv11 Vista design for centrigugal compressor and pump is new,also in cfx tutorials u will find both tutorials for pump as well as compressor describing from bladegen,turbogrid to cfx.
Yaa in bladegen u can deal with propeller geometries, u can find one axial fan example,search for .bgd files through windows,u will find all examples.
Also for any helps u can type in the search index from bladegen help from bg gui.
I think alomost all things u r searching will be available now.
Regards, Pankaj.
Old   November 8, 2007, 00:06
David Wang
Hi Pankaj:
Thank you for your response.
I have already done the tutorial practice of axial fan. But my model is a high skew propeller with NCCA16. The blade tip only has one point, but bladegen require the blade has a surface in shroud. Need I change the geomotry? If it need change,how to do? If I Only change the blade tip to a small surface, it's grid quality plotting in trubogrid will be very bad. Cloud you give me some advice about this problem?
Old   November 8, 2007, 00:30
David Wang
In addition, I have the BladeGen.hlp file, but there have little content to introduce the IMPORT DATA WIZARD funtion. It tell me to refer to the bgImport.hlp file, however, I searched this file and not find it in my windows. It's not install problem.My version is 11.0 and I don't kown whether it have in ANSYS Product 11 sp1 version.
Regards, David.
Old   November 21, 2007, 07:30
pankaj
hi david!
too late to reply.
bladegen is a kind of software where u need to practice a lot with all type of geometries.
as it uses r theta z cordinate system,u can get cordinates if u know x,y,z.
help will just describe u how to start,no more details r there.u have to do it of your own and ofcourse it comes with every version,search in "C:\Program Files\ANSYS Inc\v110\AISOL\BladeModeler\BladeGen".
Regards, Pankaj.
DonGunner94 likes this.
Old   April 2, 2016, 05:18
Default Calculating warp angle and flow angles
ashwani
ashwani.thakur is on a distinguished road
Can any one guide me as to how calculate the Warp angle and flow angle from the airfoil shape, I have airfoil data of rotor blade but hoe to input the blade angles from it in ti blade gen.
Thanks
ashwani.thakur is offline   Reply With Quote
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
