distortion of mesh while loading the report
Old   November 8, 2007, 05:22
Default distortion of mesh while loading the report
fkonias
When loading the results in the cfx-post a message box appears: an appropriate report template was found for this case. Turbine rotor report. Load y/n? I choose yes, but while loading, it distorts the mesh and all the reports end up wrong. To be exact the polyline at the 20% and 80% span is not constant but it looks more like a sin(x) plot. I don't know what is causing it and what is affected by it! How can I fix that?
Old   November 9, 2007, 06:49
Default Re: distortion of mesh while loading the report
johnny
Make sure your turbo initialization is correct. If it's not, the meridional space can be all messed up, and span plots can look strange.
Old   November 9, 2007, 07:40
fkonias
But at the time I only run steady state with frozen rotor and so there is no initialization(first run of a series). The problem appeared after increasing the number of blades that were to be modeled, for the rotor. I did that so the pitch would get closer to unity.
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[GAMBIT] Face Mesh distortion Forrest ANSYS Meshing & Geometry 0 June 9, 2009 11:50
cfx mesh loading problem u k jha CFX 3 April 29, 2009 12:41
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
