Can anybody help me? (Turbine blade simulation)
Old   December 17, 2007, 05:10
Default Can anybody help me? (Turbine blade simulation)
Amisa
Hi
I want to simulate a turbine blade flow by CFX but I have many problems. I have following information:
Blade inlet:
Ttotal=409.5 K Mach=0.25 a=30 deg
Blade exit:
Mach=0.92
Blade surface: T wall=298 K
I have made grid in ICEM-CFD. If anybody gave me promise to try it, I would send ".geo", "gtm", ".def" and ".cfx" file.
Regards,
Old   December 17, 2007, 06:41
Default Re: Can anybody help me? (Turbine blade simulation
Anantha
I feel it's better that you state your problems here; the ones you are facing when trying to simulate the turbine. Guys over here may be able to address those. I guess it's bit harsh to ask some one to solve your problem as such..!!However, what kind of simulation are you performing. I could see inlet mach number 0.25 and exit 0.92 !!!!
Regards Anantha
Old   December 17, 2007, 08:27
Amisa
Hi Anantha
Thank you. I do not want someone to solve it. I want to send .cfx file that anybody have a look at it and see if boundary conditions and other settings are correct.
Regards,
Old   January 7, 2008, 03:24
maddy
dear friend, can u send to me also so that i can see the details & possiblly hep u?
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 02:33
[ANSYS Meshing] Mesh elements inside turbine blade eoinsturbine ANSYS Meshing & Geometry 2 May 15, 2011 11:44
force acting on gas turbine blade.... vvj Main CFD Forum 1 March 3, 2010 01:04
wind turbine simulation moca CFX 1 July 25, 2009 06:48
Wind Turbine simulation Bharat FLUENT 0 August 18, 2005 04:38
