LES turbulence models
Old   February 1, 2008, 17:34
Default LES turbulence models
kaama
Is there any other turbulence model that we can choose in CFX other than Smagorinsky's model. If CFX provides only smagorinsky's model for LES then it puts a serious question mark on its capability with respect to LES. Would you guys agree?
kaama
Old   February 1, 2008, 21:18
Default Re: LES turbulence models
Dre
In CFX-Pre, go to Edit -> Options -> CFX-PRE and check the "Enable Beta Features" -> Apply
You should now see 3 LES models :
- Smagorinsky - WALE - Dynamic Model
Old   February 2, 2008, 07:08
kaama
How come there is no info on these models in documentation. When we need to select our turbulence model under domain profile even then we see only smagorinsky model. When i did not find any info on these models i assumed CFX only does Smagorinsky model.
I am kind of embarrased now because i have been using CFX for four months and i cosistently told my supervisor that CFX only does smagorinsky's model. Thank you Dre
kaama
Old   February 3, 2008, 16:48
The additional models are beta features and therefore not discussed in the manual. They area also not guaranteed to be bug-free - again they are beta features only. There are lots of hidden features like this in CFX, so if you want to do something which is not discussed in the manual it is always worth talking to CFX support about it as it might be a beta beta which is hidden.
Also, in your case most LES SGS models are quite simple and could fairly easily be written and put into CFX. Just because Smagorinsky is the only model listed does not mean that is the only model it can do.
Default inlet turbulence for LES N Barton CFX 11 July 24, 2015 00:34
Accuracy of Boundary Layers With Turbulence Models de5truction FLUENT 2 June 3, 2011 18:36
boundaryFoam, axisymmetry and turbulence models thomas_toulorge OpenFOAM Running, Solving & CFD 0 May 12, 2011 13:05
Turbulence Models and external flow. Alan FLUENT 3 November 22, 2005 04:46
LES turbulence model problem-HELP James Willie FLUENT 2 August 23, 2005 04:54
