a simple question
Old   February 18, 2008, 11:48
Default a simple question
Al Mazdeh
Guys, I am new to cfx
what is the difference between cmdb and gtm file
I suppose that gtm is a file I am following an example in cfx toturial (example1)
and after creating the volume mesh when I save the file , a cmdb file gets created bit the instruction says a gtm file should get created
is there any difference
thank u for the inputs
Old   February 18, 2008, 13:41
Default Re: a simple question
KK
cmdb file has ALL the information regarding the face/line spacing, element size, inflation layers, 2D composite zone etc.....every information which you might need if you want to modify your mesh in CFX-Mesh (inside workbench)
While gtm file JUST has the mesh and details of 2D regions created at the time of mesh generation.
you can use either of two files in CFX-Pre....
cmdb should take more memory to store.
you can change your settings in workbench if you want to save for cmdb and gtm files...otherwise it will only save cmdb files
Old   February 18, 2008, 14:48
Al Mazdeh
thanks
Simple Outlet Question m.nichols19 OpenFOAM 3 June 25, 2010 01:44
Simple Question Regarding Symmetry Planes Atella CFX 3 April 11, 2010 06:44
Simple Question Regarding Symmetry Planes Atella Main CFD Forum 0 April 9, 2010 10:58
Question of Anil Date's SIMPLE method universez Main CFD Forum 0 November 18, 2009 20:12
Simple Question Regarding Continuity Closure RC FLUENT 2 March 25, 2004 05:30
