Fluidized Bed Simulation
Old   July 14, 2006, 03:31
Default Fluidized Bed Simulation
Siaw Khur
Hi, I am facing problems in simulating the fluidized bed reactor. Please advise me if anyone has the experience in fluidized bed reactor simulation. Many thanks!
Old   July 14, 2006, 09:10
Default Re: Fluidized Bed Simulation
user
hi khur,
are you doing gas /solid or liquid/solid fluidisation
with regards user
Old   July 14, 2006, 20:51
Siaw Khur
Hi there, I am doing gas-solid fluidization. Do you have experience simulating this environment?
Regards, Khur
Old   July 16, 2006, 16:22
Info-guy
ask star-cd support they have a lot of papers on this (www.cd-adpaco.com)
Old   July 17, 2006, 08:43
user
hi can u post the problem u have in modeling of gas solid fluidsation
bye
Old   July 17, 2006, 21:45
Siaw Khur
Hi there, I have failure in my solver. The solver couldn't be run. I defined 2 domains in my simulation in order to divide the solid phase (static bed) and gas phase (fluidizing agent). A separate region was self-generated in my reactor for defining the static bed, however i am not sure that whether the static bed was being defined properly.
By the way, what is your email address? if you wish to send me some CFD information, please send to wkhur@yahoo.com
Below are the messages that i obtained in the solver. +--------------------------------------------------------------------+ | Reference Pressure Information |+--------------------------------------------------------------------+ Domain Group: Domain 2
Pressure has not been set at any boundary conditions. The pressure will be set to 0.00000E+00 at the following location:
Domain : Domain 2
Node : 1 (equation 1)
Coordinates : ( 1.50000E-01, 1.50000E-01, 0.00000E+00).
+--------------------------------------------------------------------+ | Average Scale Information |+--------------------------------------------------------------------+ Domain Name : Domain 1
Global Length = 1.6543E-01
Minimum Extent = 1.5000E-01
Maximum Extent = 4.1000E-01
Density = 1.1850E+00
Dynamic Viscosity = 1.8310E-05
Velocity = 2.5000E-01
Advection Time = 6.6172E-01
Reynolds Number = 2.6766E+03
Domain Name : Domain 2
Global Length = 1.5000E-01
Maximum Extent = 1.5000E-01
Velocity = 0.0000E+00
+--------------------------------------------------------------------+ | Checking for Isolated Fluid Regions |+--------------------------------------------------------------------+ 4 isolated fluid regions were found in domain Domain 1
If the isolated regions do not have the pressure level set either by the boundary conditions or using a reference pressure equation,you may encounter severe robustness problems.
This situation may have arisen because a domain interface was not properly defined during problem setup. Please carefully check the setup.
The solver will stop now and write a results file. The isolated regions can be visualised in CFX Post by making plots of the variable "Isolated Volumes".
If you are sure that the pressure level is set in each isolated fluid region then you can force the solver to turn off this check by setting the expert parameter "check isolated regions = f".
Old   July 17, 2006, 21:52
Siaw Khur
Hi Info-guy,
Thanks for your information. I have checked on the website that you've given me. Now still pending for the reply from one of the person that i've contacted. Hope that star-cd's features are more or less similar to CFX's.
Do you have any published papers on how fluidized bed reactor is being simulated in CFD?
Thanks
Old   July 24, 2006, 08:36
Phil
It sounds like you have some setup problems. There should not be any isolated regions... it means you have spurious walls set up in various places.
When you set up the problem, you should use a single domain rather than multidomains, and use the CEL 'step' function to initialize air/solid regions.
For further help, contacting your local support person is a good idea.
Phil
Old   July 25, 2006, 01:56
Siaw Khur
Hi Phil,
Thanks. I think i have serious problem in the setup. I have contacted the local support person, but i got no reply from them. I need to get the problem sorted out soon as it affects my research progress. Do you have experience in simulating bubbling fluidized bed? Hope that you can advise me if possible. Many thanks.
Regards, Siaw Khur
Old   July 28, 2010, 14:43
Germán González Silva
germangsilva is on a distinguished road
Send a message via MSN to germangsilva
hello
I'm doing studies of fluidized bed (gas-solid), I'm using cfx11 or 12, and applying LES, but I have great difficulty setting the program cfx, I ask your help, please. my email is germangsilva@gmail.com.
germangsilva is offline   Reply With Quote
Simulation of a fluidized bed sydney_tekam Main CFD Forum 0 April 12, 2010 08:24
fluidized bed ali CFX 1 January 9, 2008 02:40
Questions about gas-solid fluidized bed simulation Sinferm FLUENT 1 January 31, 2007 14:54
A question about gas-solid fluidized bed! mactonald FLUENT 0 November 7, 2003 06:28
Central jet injection in a fluidized bed Mike Main CFD Forum 0 April 26, 2002 15:14
