March 13, 2008, 10:38 |
Negative Total Pressure
Here I am again...
In a simulation I found a negative total pressure in a contour plot... Anybody can explain me how it is possible??? Thanks J |
March 14, 2008, 10:28 |
Re: Negative Total Pressure
The Total Pressure (aka Stagnation Pressure) is reported relative to your domain reference pressure. Don't confuse it with Absolute Pressure, which is the static pressure + relative pressure.
Also, if you fluid is incompressible, any pressure is possible. If fluid properties are not dependant on pressure, then all pressures are relative (i.e. if you add the same pressure, say Poffset, to all your boundary conditions, the solution is the same, but the pressure is offest). In reality you don't have negative pressures because density changes with pressure in a gas and liquids boil/cavitate when the pressure is low enough. If you include this behavior in your model, you won't see negative pressures. -CycLone |
April 5, 2008, 07:24 |
hi i am also faced same problam i give inlet mass flow==1kg/sec and static pressure= 8bar outlet avrage static pressure= 3bar i given. but when ever i seen post results plot is comming nearly 20 bat comming. how is rectifying. please give me responce thanking you bye
total pressure change in a pipe flow | Im | FLUENT | 5 | February 23, 2017 08:55 |
negative pressure in cfx | flar.t | CFX | 1 | December 18, 2006 23:20 |
negative pressure | mAx | FLUENT | 0 | January 25, 2006 14:31 |
Negative Pressure | S Christopher | CFX | 2 | October 6, 2005 18:14 |
Total pressure to static pressure ratio | roadracer | Siemens | 1 | April 17, 2003 05:31 |
