Urgent Problem with Hypermesh and CFX
Old   February 29, 2008, 05:12
Default Urgent Problem with Hypermesh and CFX
Luk
Hi all, I have strange problem with exporting mesh from Hypermesh to Ansys CFX. I'll try to describe it: - I have a very simple model of cube, with airflow through, - I preapre surface mesh in HM, - from these surface elemens I perform volume meshing (in HM also) with prism boundary layers, forming PENTA ELEMENTS. - when I export it to CFX (through nastran format) I found that there are holes inside model just next to boundary layers. I was digging here a little bit and found that this is because there are pyramid5 elements which are not handled by nastran template in HM, - going back to HM i decided to split every penta5 element into two tetra4 elements. This division is performed such a way, that penta5 side with 4 nodes is split into halves and shared between tetras. My problem is that if I export it to CFX it produeces faces on these surfaces (split sides of penta5 elements). Now I have no holes in geometry, but there are surfaces inside the cube (like plane elements for boundaries).
Can anyone any experience how to handle this problem? I would be very grateful for help because matter is very urgent.
Luk
Old   February 29, 2008, 09:49
Default Re: Urgent Problem with Hypermesh and CFX
CycLone
Try exporting through CGNS.
Old   February 29, 2008, 10:18
Luk
Thanks for Your help but I simply must ask this question: how to do that from HM? I have HM 7.0 and there is no such option for export nor for template to load. It would be very real great to solve it.
Luk
Old   February 29, 2008, 11:30
CycLone
I have no idea, have you contacted Hypermesh support?
Old   February 29, 2008, 11:40
Luk
At the moment I am trying to do it myself. I found that, there are only 3 templates in hm (for hm, pamcrash and madymo) which can handle the pyramid5 elements properly.
Luk
Old   March 14, 2008, 04:59
Default help me please
kamalhasan.kasi
hi i got one component with 10 mm mesh.my client asked me to that do with 5mm mesh with in a short time.shall re mesh 10mm to 5 mm. if do like this will i get any problem in Q.C.and will it come as per the geometry.
thanking u,
yours obediently,
kamalhasan.kasi
Hypermesh to cfx XTYY CFX 0 July 24, 2009 06:42
mesh quality to CFX thiagu CFX 4 December 4, 2008 00:55
Hypermesh Export Kieran Hood CFX 1 February 7, 2007 17:45
hypermesh and CFX garywang CFX 2 April 24, 2005 20:20
how about Hypermesh software Kulasekharan FLUENT 4 October 15, 2004 11:51
