March 18, 2008, 23:57 |
help on mass sink using CEL function
Hello CFX experts,
I want to set a sink(mass flux) for the walls using the equation: flux=rho(const)*void*velocity. But I want to use the values of void and velocity at a certain point below the wall (e.g. 2mm below the wall). I'm not sure if USER_GETVAR can get it since it's away from the wall, but if yes how would I get those values at my desired points? I did something before but in a different way, I used monitor/source pts in PRE and send the void and vel values at those points to fortran using the CEL function. But it's very limited since I have to make so many points. I want to do it in a general way. Hope you have some insights about this. Thanks a lot guys! Ariel |
LiencubiclowRemodel | nzy102 | OpenFOAM Bugs | 14 | January 10, 2012 08:53 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
OpenFoam 14 installation problem | gfcoppola | OpenFOAM Installation | 20 | November 2, 2007 13:38 |
Mass fraction via Cel file at outlet | Jens | CFX | 3 | April 28, 2003 09:14 |
