Frictional losses at wall
Old   May 6, 2008, 10:47
Default Frictional losses at wall
Sans
I have an elbow tube with some amount of flow separation in it. I m trying to break down the losses. Hw do I calculate the frictional losses/pressure loss due to friction at the wall using CFX Post?
Thanks, Sans
Old   May 23, 2008, 04:09
Default Re: Frictional losses at wall
Mehul
Sans,
I think it is not possible in a straight way , so far as I know. But if you can formulate a function using CEL expressions, and that function will be calculated for every iteration, then I think it could be possible but I am not sure. Other wise you can calculate the overall pressure drop only, not pressure drop because of friction losses only.
Regards Mehul
UDF to Access Wall Normal Concentration Gradient Daniel Tanner Fluent UDF and Scheme Programming 4 February 18, 2015 14:35
Very technical question about solving wall boundary layer ... jlb001 FLUENT 6 December 27, 2014 05:56
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
Wall functions? Pr Main CFD Forum 7 April 8, 2004 06:15
Quick Question - Wall Function D.Tandra Main CFD Forum 2 March 16, 2004 04:29
