Using results form previous run as inlet condition
Old   June 9, 2008, 09:22
Default Using results form previous run as inlet condition
lauren
Hi Everyone,
For my simulation, I'm trying to use data (velocity profile at outlet) for a previous simulation file as input data for the new one.
I have followed the procedure :
1. Export outlet velocity profile to a csv file in post.
2. Initialise this profile data in pre & use it for your boundary condition.
That's where start my problem. As I'm using SST model for turbulence, I need to specify a turbulence level at the Inlet. But I could find a way to use my data for that.
Is it a way to overcome this issue? all suggestions are welcome.
Thanks.
(Sorry for my english)
Old   June 9, 2008, 11:09
Default Re: Using results form previous run as inlet condi
icem-noob
just pick the steady-state results in the solver and voila... that's it
Old   June 9, 2008, 11:38
CycLone
Hi Lauren,
Go back to Post and export the profile again. This time choose "Custom" for the profile type and pick the variables you need
Momentum: Velocity and/or Total Pressure Energy: Temperature, Total Temperature or Enthalpy Turbulence: Turbulence Eddy Frequency (or Dissipation) and Turbulence Kinetic Energy
At your inlet, set the turbulence option to "k and Omega" if you have Turbulence Eddy Frequency, or "k and Epsilon" if you have Turbulence Eddy Dissipation.
-CycLone
Old   June 9, 2008, 13:32
lauren
Hi Cyclone & Icem-nood,
Thanks for your precise and effective answers. I have try it and it seems to work well.
Once again thanks a lot.
Best regards.
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
How to use a solution as an inlet boundary condition in another problem in fluent geryes FLUENT 0 February 25, 2010 16:32
Using results form previous run as inlet condition M CFX 2 January 16, 2006 22:43
inlet and outlet boundary condition of pump Thammasak CFX 0 February 9, 2004 13:02
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
