pressure drop between inlet & outlet
Like Tree2Likes
  • 2 Post By Ahmed
Old   June 12, 2008, 15:38
Default pressure drop between inlet & outlet
Ahmed
Hi guys
I have a LES solution for a plane duct. I want to calculate pressure drop between inlet and outlet so that I can use that value to run the case with periodic BC. How do I calculate pressure between inlet and outlet from post. Thanks you for your help.
Ahmed
Old   June 14, 2008, 03:56
Default Re: pressure drop between inlet & outlet
Jaloha
Hi,Ahmed, In CFX-Post, you can use the "export" function by selecting File-->Export, then in the prompted dialogue box, firstly choose a Location (in your case should be "Inlet" or "Outlet"); Secondly, select a variable(in your case should be "pressure") in the "Select Variable(s)" list box. Finally, click "Save", then a .csv file(can be opened by Excel) will be saved to the working directory. Data in the .csv file are the pressure values correspoding to different positions of the "Inlet"( or "Outlet") surface. I guess the values shall be nearly the same because the "pressure" variable stands for the "static pressure". After you get the two pressure values by this method, problem will be solved. I hope this helps.
Old   June 14, 2008, 06:43
Ahmed
Hi Jaloha
Thank you for your answer. I was looking for a single value of pressure. In other words I want to know what my pressure loss is within duct so that I can use that figure to run periodic case.
Ahmed
Old   June 14, 2008, 09:13
Jaloha
Hi,Ahmed I'm not sure if you have tried the method I suggested. You have to do that in two steps. First you get the pressure value of the inlet surface by exporting a .csv file, then do it again to get the pressure value of the outlet surface, so that you can get the pressure drop by calculating the difference between the two values. Hope you can make it. Good luck!
Old   June 14, 2008, 11:50
Ahmed
Thanks Jaloha
Old   June 14, 2008, 12:05
Ahmed
I figured out how to find the pressure difference from post. I can use the expression areaAve(Pressure)@Outlet-areaAve(Pressure)@inlet. Thanks
Ahmed
zobekenobe and chaitanyaarige like this.
Old   June 14, 2008, 13:49
Jaloha
Congratulations, I'm glad to hear that.
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 12:30
Validation 12.1 vs 6.3, Difference in Reported Inlet Total Pressure jola FLUENT 1 May 5, 2011 14:33
Pressure Rise Error emueller CFX 0 May 5, 2009 11:08
Pressure drop trend phyiscal not correct in t pipe Vinod FLUENT 0 August 4, 2008 02:43
Mass flow inlet and pressure outlet BC in star-cd? sreenivas Siemens 4 February 22, 2008 01:52
