July 21, 2008, 17:00 |
Imposing outlet values of longer duct
Hi guys
Can I impose outlet values of longer duct, which I have run as steady state, on my actual duct which I want to run as unsteady state. Regards |
July 21, 2008, 22:20 |
Re: Imposing outlet values of longer duct
You should be able to save it as a BC profile and use that in your transient boundary condition. Glenn Horrocks |
July 22, 2008, 05:48 |
Thanks Glenn.
Regards |
July 22, 2008, 09:28 |
On CFX-Post, create a file in exporting a file.dat with the coordinates x,y, and z plus your values of your variable! You must create a plane or a line to do this on the outlet of your computational domain!
July 23, 2008, 13:49 |
Hi Rogerio
Thank you for your answer. Can I not simply export BC profile of my results? For location I can select inlet and profile type as Inlet Velocity. Is this method correct? Regards |
July 23, 2008, 14:17 |
Output tab => CFX-Pre: create some points (x,y,z) on outlet with velocities and after that, u will able to use them on the next simulation! Itīs easy!
July 23, 2008, 16:02 |
Can I also use BC profile?
Regards |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
Outlet values of longer duct | underGroundMan | FLUENT | 0 | July 21, 2008 17:03 |
Outlet values of longer duct | underGroundMan | Main CFD Forum | 0 | July 21, 2008 17:01 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 17:49 |
Impinging Jet. Outlet Boundary Condition | Vincent | Main CFD Forum | 0 | December 16, 2003 10:49 |
