September 27, 2018, 22:25 |
Transient Simulation in CFX
Ashkan Javadzadegan
Rep Power: 16 |
I have a fundamental question about transient simulation in CFX. Let’s assume I want to perform transient blood flow simulation in an artery over one cardiac cycle. Simulation (1). As per the conventional transient CFD, I setup my model and run the transient simulation. For post-processing I divide the cardiac cycle into 6 time fractions and calculate the time-averaged haemodynamic parameters in each fraction (please see the attached image). Simulation (2). Now I want to repeat the same simulation but using a different approach. I split the transient simulation into 6 separate transient simulations and calculate the time-averaged haemodynamic parameters for each simulation. What difference should I expect to see in the corresponding time-averaged haemodynamic parameters derived from Simulation (1) and Simulation (2). Thanks |
September 28, 2018, 01:18 |
Rep Power: 143 |
The image was not attached. But please think carefully about your question - is it answerable? From what I have seen so far it is not answerable. If your images define the different approaches you talk about then consider whether your question will require expert knowledge of cardiac modelling to answer - again, this is not answerable (at least on the forum).
MEMERR-Problems on a transient turbomachinery simulation | Stuntmanbob | CFX | 9 | May 5, 2016 05:22 |
Boundary condition setting regarding turbine simulation using CFX | Lacerlacer | CFX | 11 | March 12, 2012 09:32 |
Problems on H2/air CFX simulation | xulixian | OpenFOAM Running, Solving & CFD | 2 | April 14, 2009 15:00 |
how to identify transient simulation converged | littlelz | CFX | 5 | January 27, 2009 18:13 |
transient simulation: natural convection problem? | Basics | CFX | 3 | September 25, 2002 09:42 |
