[Sponsors] | |||||
I am modelling a buoyancy driven flow in a horizontal concentric cylinder at high rayleigh number. After doing some research, i have narrowed down my turbulence model to either the SST k-w or the Reynolds stress BSL k-w model. However, i am finding it difficult to get a converged solution. I've sent the convergence criteria to 10^-5. I only used automatic initial conditions given in CFX. Does anyone know what initial values i should use? How can i check if my solution is correct? |
Which transport equations specifically are you having difficulty converging?
In general the SST model is more stable than the Reynolds Stress models. You might try to get an initial solution using the BSL model and then restart it with SST. Also, CFX uses the first order upwind differencing scheme as default for the calculation of the Reynolds Stress and turbulence parameters (this is true even if you specify the high resolution scheme over all). You might try to run them high res to see if that helps. You'll have to manually change that in the CCL, though. You could also try setting the expert parameters turbulence diffusion scheme = 2, turbulence posdef option = 1 and varying their values. |
The navier stokes and heat transfer equation are not converging....both of them a fluctuating at 10^-4.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 121 | March 7, 2013 17:21 |
| SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 04:13 |
| Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
| Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM | 6 | April 12, 2011 11:24 |
| Negative value of k causing simulation to stop | velan | OpenFOAM Running, Solving & CFD | 1 | October 17, 2008 05:36 |
