How to Define Rotation Quaternion in CFX Post
Old   August 19, 2008, 16:30
Default How to Define Rotation Quaternion in CFX Post
ahlo
I am going to make batch processing to get images from different view angle by modifying and playing session file with different view orientation data. To define the view orientation, one needs to define Rotation Quaternion (four numbers). My question: how to calculate these four numbers if I have 3 Euler angles? or other data are needed as well to produce this four-number Rotation Quaternion?
A sample session file is attached as following.
Thanks Ahlo
------------------------------------------------------- # Session file started: 2008/08/18 16:09:59 # CFX-11.0 build 2007.01.10-23.00
# To avoid unnecessary file pre-processing and modifications, include # COMMAND FILE at the top of your session file. # If it is not included, the file is assumed to be older and will be # modified for backward compatibility. COMMAND FILE: CFX Post Version = 11.0 END
VIEW:View 1 Camera Mode = User Specified CAMERA:
Option = Pivot Point and Quaternion
Pivot Point = 0, 0, 464.726
Scale = 0.00296
Pan = 0, 0
Rotation Quaternion = 0.00437162, -0.00189465, -0.0080251, 0.997973
Send To Viewer = true END
END
Transient animation performance in CFX 5.5 POST Sjoerd Romkes CFX 8 February 5, 2013 14:53
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 09:23
How to set domain translation and rotation in CFX ricardo.halfeld CFX 7 September 8, 2009 18:22
CFX Post export problem jeff_F CFX 0 August 17, 2009 21:25
chart for transiente simulation - CFX Post rogbrito CFX 0 June 22, 2009 12:12
