Mesh similar to tutorial 20
Old   August 26, 2008, 04:19
Default Mesh similar to tutorial 20
Marie S
Hey'a all
In tutorial 20 (with the fortran mesh-reading option) the instructions says:
* The coordinates of the first mesh in the sequence must be identical to the initial solver-internal mesh coordinates.
* The topology (i.e., connectivity) of all meshes in the sequence does not change.
So, I have two questions: 1)How is it possible to generate a sequence of meshes since the topology needs to be the same? Should I generate one mesh, and then update the geometry and hope that the old mesh keeps the topology?
2)What format does it need to be in, to be able to use the fortran routines? I opened DeafultDomain.0 and it seems like the first row is just an integer saying how many coordinates there are, and then there are three columns with the coordinates. Is it possible to export to that format from ICEM?
best regards
Marie
Old   August 27, 2008, 04:25
Default Re: Mesh similar to tutorial 20
Marie S
No one who knows?
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
How to read a mesh from a directory other than the default tutorial directory mali28 OpenFOAM 1 July 6, 2011 14:08
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
