Setting up a point monitor rotating with the blade
Old   September 11, 2008, 21:07
Default Setting up a point monitor rotating with the blade
Hamidur
Hi Guys I have been doing a stator-rotor transient simulation. In order to see the change of flow characteristics with respect to time at a particular location, I specified a Cartesian point in the space of the rotor section. As you know the rotor is rotating at a constant speed in this transient case. I am interested to see the instantaneous result of a variable (e.g pressure)where the point is rotating with the rotor itself.
How the point can be made rotating along with the rotor as seen from the stationary frame of reference?
I appreciate your kind response please.
Thanks
Old   September 13, 2008, 17:00
Default Re: Setting up a point monitor rotating with the b
johnny
A monitor point in a rotating frame of reference is in fact rotating in the stationary frame of reference. When you define cartesion coordinates for a monitor point, it actually gets tagged to the nearest node to the x,y,z location, and it sticks to that node for the rest of the simulation.
Also, in a transient rotor stator run, the mesh does not move. The equations are simply solved in the relative frame of reference with source terms added to account for Coriolis effects, centrifugal forces, etc. The results at the interface are numerically pitched and the results are passed across the interface.
[ANSYS Meshing] Mesh elements inside turbine blade eoinsturbine ANSYS Meshing & Geometry 2 May 15, 2011 11:44
blade to blade 2D CFD Hina Main CFD Forum 0 December 30, 2010 09:14
Plot data for a fixed point aut_iut OpenFOAM 0 December 23, 2010 05:16
CFX Post: Problems with moving point cloud for changing time steps spatialtime CFX 0 December 7, 2009 04:56
Setting number of digits after the point using Gam Miri FLUENT 0 March 21, 2005 06:00
