Tube in Tube heat exchanger( But I got error)
Old   September 24, 2008, 00:35
Default Tube in Tube heat exchanger( But I got error)
Young
Dear all,
I have tried to simulate a heat exchanger.
Water is flowing at outer pipe and air is flowing at a inner pipe as following sectional diagram
water -->
air <--
water -->
I had two fluid domain (water, air) so I used "enable beta features (in option)" and turned off "constant domain physics" at simulation.
But I got error message like this
*********************************************** Global Statistics :
Global Number of Nodes = 31926
Global Number of Elements = 96078
Total Number of Tetrahedrons = 96078
Global Number of Faces = 58222
Minimum Orthogonality Angle [degrees] = 32.3 ok
Maximum Aspect Ratio = 6.4 OK
Maximum Mesh Expansion Factor = 21.8 !
Domain Interface Name : Domain Interface 1
Non-overlap area fraction on side 1 = 8.89E-06
Non-overlap area fraction on side 2 = 5.07E-08 ---------------------------------- Error in subroutine FNDVAR : Error finding variable DENSITY_FL1 GETVAR originally called by subroutine GET_MFLOIP_ZIF
+--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ ---------------------------------- Error in subroutine FNDVAR : Error finding variable DENSITY_FL1 GETVAR originally called by subroutine GET_MFLOIP_ZIF
+--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+
End of solution stage.
+--------------------------------------------------------------------+ | Warning! | | | | The ANSYS CFX Solver has written a crash recovery file. This file | | has been saved as F:\Thesis\prelim\test\001\model3_004.res.err and | | may be an aid to diagnosing the problem or restarting the run. | | More details should be available in the solver output section of | | the output file. Note that a lock file was left for the crash | | file when the solver exited, and so it is probably incomplete. | +--------------------------------------------------------------------+
+--------------------------------------------------------------------+ | The following user files have been saved in the directory | | F:\Thesis\prelim\test\001\model3_004: | | | | mon | +--------------------------------------------------------------------+
This run of the ANSYS CFX Solver has finished.
Would you let me know how I get over error?
and please share your exprience, if you have ever done this type heat exchanger.
Thanks have a great day
Old   September 25, 2008, 19:36
Default Re: Tube in Tube heat exchanger( But I got error)
The first error says that is can't find the density for a material. Check that you have density defined for everything, or a sensible equation of state defined.
Old   September 26, 2008, 01:35
Young
Dear Horrocks,
Thanks your response.
I use each fluid material as follows;
air = Air at 25C in CFX material library, its density is 1.185 kgm^-3 Water = water in CFX material library, 997 kgm^-3
However, it makes the same error message.
I suspect this issue is caused by interface condition.
But I don't know what makes errors.
I think it is simple crossflow heat exchanger between air tueb and water tube.
Have you ever run before?
Thanks
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
