Wing Generation
Old   September 23, 2008, 10:21
Default Wing Generation
Jenniefr
Hi there
I am trying to generate a wing/rotor within Design Modeler in CFX and I can input my naca aerofoils without a problem but when it comes to blending them together to form the wing and adding a twist I cannot seem to achieve this. Has anyone had any experience with this? Can anyone help? Step by step instructions would be most helpful as with any suggestions. Thanks for your time.
Jennifer
Old   September 23, 2008, 19:29
Default Re: Wing Generation
Complicated surfacing such as this is not easily done on Design Modeller. I would use a more advanced surfacing tool such as a solid modelling package (ProE, Catia, Solidworks, UG etc) or rhino.
Regards, Glenn Horrocks
Old   September 24, 2008, 05:37
siw
I've also had no success making 3Dwings in DM by importing aerofoil co-ordinate data so ended up using our CAD package - Solid Edge. So a step by step would be useful.
But be aware if you use solid edge, we always find that CFX-mesh fails by putting elements INSIDE the wind at the root leading edge when a line control is used along the leading edge and ANSYS have not been able to explain why. If we supress the line control it's okay but we use if to refine the element size here as stuff is happening to the flow; it's slowing down.
Old   September 24, 2008, 06:28
siw
Or a point control at the root leading edge, at attempt just failed aswell.
Old   September 25, 2008, 19:40
Hi siw,
Sounds like you have found a bug in Workbench V11. I would talk to support about testing it on V12 beta and if still present then report it as a bug. Then with any luck it can be fixed for the release version.
Old   September 26, 2008, 01:39
F S
Hi
Try bladegen.
best of luck
Mesh generation for bird wing breff89 Main CFD Forum 0 January 21, 2011 07:00
3D wing mesh generation DoHander Main CFD Forum 0 July 16, 2010 16:01
Latest News in Mesh Generation Robert Schneiders Main CFD Forum 1 February 18, 2000 00:48
Latest new in mesh generation Robert Schneiders Main CFD Forum 0 February 16, 2000 07:12
Latest news in mesh generation Robert Schneiders Main CFD Forum 0 March 2, 1999 04:07
