Concentric Tube Heat Exchanger Analysis
Old   January 22, 2005, 07:24
Default Concentric Tube Heat Exchanger Analysis
Abhishek
HI. I am a M.E. student at VJTI Mumbai.
I have to carry out heat transfer analysis between two fluids through a solid region using CFX . I have built a simple model of two concentric tubes. Hot fluid flows throught the outer tube whereas cold through the inner. The two fluids are seperated by copper tube . How should I simluate these conditions so that the cold fluid gets heated by the hot fluid through solid copper.
Can anyone please guide me.
Old   January 23, 2005, 16:25
Default Re: Concentric Tube Heat Exchanger Analysis
This type of model is called "conjugate heat transfer" or CHT. There is an example CHT simulation which comes with CFX.
Old   September 29, 2010, 08:56
Thumbs up same prob for me
Satheeshkumar
satheeshmech is on a distinguished road
hi abishek,
i have a same problem., if u know pls answer me, mail me to satheeshmech@gmail.com
satheeshmech is offline   Reply With Quote
Old   November 8, 2011, 05:45
Default Ur query
sandeep
sandeepshrijoshi is on a distinguished road
CFX version 1 can be better option just chk it out
Originally Posted by Abhishek
;70792
sandeepshrijoshi is offline   Reply With Quote
Heat Exchanger Model sak2129 FLUENT 3 September 26, 2017 01:29
Recommendation for CFD software james15 Main CFD Forum 11 May 19, 2011 08:32
Pressure drop in a heat exchanger Diana FLUENT 5 December 13, 2007 09:33
Concentric tubes heat exchanger FTM CFX 6 April 10, 2006 18:14
concentric tube heat exchanger satya CFX 4 January 16, 2002 09:06
