January 7, 2009, 05:15 |
Fan rotating model
Dear CFD Friends,
I need your helps and suggestions on developing transient rotating Fan which is in the room. I need to capture the flow behavior of transient rotational effect. Kindly provide me how to to do Domain interfacing and what MFR to be used. Thanks and regards Raj |
January 7, 2009, 17:29 |
Re: Fan rotating model
To capture transient behaviour in a rotating machine you need the transient-rotor-stator model. This is all discussed in detail int he documentation and there are some tutorial examples to help you get started. Have a look in the documentation. There is also a best practices guide for turbomachines which you should look at. Glenn Horrocks |
January 8, 2009, 04:11 |
Hi Glenn,
Thanks a lot for your email. I have gone thru the materails. Kindly let me know what kind of interface should we put between stationary and rotating domain to capture the swirl flow. What do I need to set in solver expert parameter setting? I tried with the model with stator and rotor interface. But I am not able to get the swirl pattn and not able to see the proper momentum transfer across the domain. Thanks and regards Raj |
January 8, 2009, 16:22 |
The interface you need should be clear after you do the tutorial examples. No need for expert parameters, the default solver options should be fine. What do you mean "proper momentum transfer"? Glenn Horrocks |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
How to model a fan as inlet boundary condition? | val46 | OpenFOAM | 3 | October 16, 2018 13:49 |
Simulation of Axial Fan Flow using A Momentum Source Subdomain | Liam | CFX | 28 | July 16, 2013 08:24 |
FModellign a Fan Using the Disc Actuator Model | Saif-Deen Akanni | FLUENT | 5 | November 9, 2011 21:52 |
how to model a rotating sprinkler | majid | FLUENT | 0 | February 28, 2004 10:39 |
