Interface Height Tracking
Old   February 5, 2009, 02:03
Default Interface Height Tracking
YZ
I have obtained a result of 2D free surface simulation with distinctive interface. Now in the post-processing, I want to obtain the value of height of some points located at the interface. I have reviewed the similar problem someone also had, but it's still no clear to get the wanted result (the average height is assessible) even though I am able to plot the curve of x and surface height. I'll appreciate any hint from you. Thanks a lot
Old   February 8, 2009, 18:30
Default Re: Interface Height Tracking
Generate a line object from the free surface contour and export the line object and you will get XYZ points which define the line.
Old   February 8, 2009, 19:16
YZ
Got it, thank you very much, Glenn It's pretty useful for me
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
what is Interface tracking? gholamghar Main CFD Forum 1 March 18, 2009 05:58
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
