Expression for Monitor point
Old   February 12, 2009, 00:13
Default Expression for Monitor point
Yusuf
Hi! I am doing simulation of axial flow Pump. During post analysis in cfx, I found that abbsolute pressure on the suction side is to much low in some area around the blade tip so it should create the problem of cavitation. Now i want how much volume or area around blade has pressure below some value say 85 kpa,this can be found in post through isovolume but how can I put in the form of expression i cfx pre to monitor it in cfx-solver. Thanks
Old   February 12, 2009, 16:12
Default Re: Expression for Monitor point
You should be able to construct this using an additional variable. You could set an additional variable to be 1 if <85kPa and 0 if >85kPa then you calculate the volume integral of the additional variable and it will give you the volume <85kPa.
Problem About Running Fluent In Linux mitra FLUENT 18 June 20, 2019 02:11
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Lift, Drag Vs time chart,calculations Jamesd69climber CFX 8 February 17, 2005 17:23
Creating, loop or iteration using expression edito Jan CFX 3 July 28, 2003 11:01
