How to get vertex(node) number in CFX user Fortran..
Old   February 1, 2014, 05:30
Default How to get vertex(node) number in CFX user Fortran..
flyply is on a distinguished road
Hello.
I try to input the external data into the CFX.
External data was generated by 3rd party software.
Data is exactly same with mesh data, but only contain the X, Y, Z coordinate and one Scalar data. so external data array size is (total node number x 4).
anyway, At present, I match the data like this(very simple &stupid )
PRINT *, 'NLOC = ', NLOC
DO ILOC = 1, NLOC
FR(ILOC) = 0.0
DO LN = 1, NLIN
IF (ABS(X(ILOC) - TABLE(1,LN)) .LE. 0.000001 .AND.
& ABS(Y(ILOC) - TABLE(2,LN)) .LE. 0.000001 .AND.
& ABS(Z(ILOC) - TABLE(3,LN)) .LE. 0.000001) THEN
FR(ILOC) = TABLE(4, LN)
END IF
END DO
END DO
This method working well. but very slow, especially in Large Problem.
In my case, using 9 million node, It took 5 hours.
So, I try to match the node(vertex) number.
but there are no information, how to access the vertex number, in User Guide.
but, i find some clue in CFX Modeling Guide : 18.5.5.1 Message
CALL MESAGE( 'WRITE', 'Max Temp is '//CFROMR(TMAX)//’ at vertex’// & CFROMI(IVX)
'IVX' seems to Vertex number, but when i try to like this
CALL PEEKI ('/USER/'//CDIR_GLOB//'/IVX', 1, IVX,
& 'STOP', CRESLT, IZ)
It show the error message like bellow.
Details of erros:--
Error detected by routine PEEKI
CDNAM = /USER/MESH_INFO/IVX
CRESLT = NONE
Current Directory : /FLOW/SOLUTION/TSTEP10/CLOOP1/ZN1/VERTICES
Anyway, Is there anyone who knows about how to get Vertex Number in CFX user Fortran??
flyply is offline   Reply With Quote
Old   February 2, 2014, 16:18
What are you trying to do with the external data? Is it during the solver or post processing?
Old   February 4, 2014, 10:44
Hello, ghorrocks
It is for Chemical Reaction and External Data is UV intensity.
for the present, I improved the algorithm and it is worth, but not sufficient.
I take fluent into account.
Old   February 4, 2014, 17:16
CFX already has a 3D interpolation function available. But if you have millions of nodes it will probably take a while to run as well. But it might be faster than your implementation.
Old   February 4, 2014, 19:51
Yes. I already know, but 3D interpolation is very slow in my case. so I trying to do with fortran. but i will one more check the user guide about 3D interpolation.
thanks.
CFX User Fortran: Particle User Sources hustxinxin CFX 0 March 8, 2012 08:31
CFX Solver Reynolds Number haider760 CFX 2 March 4, 2012 22:05
Check particle impaction with User Fortran Julian K. CFX 3 January 12, 2012 09:46
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
how to use USER FORTRAN with CFX cfd_99 Main CFD Forum 1 June 4, 1999 05:42
