April 23, 2009, 14:51 |
solid rotation
Rep Power: 17 |
my name is Joe and I am a new member in this forum. The system I try to simulate is made out of two discs with rotational periodicity. During operation the disc rotate with different speed but the same colinear rotational axis. During operation there is a gap between the discs in axial direction with a fluid flow. The fluid has a different (higher) temperature compared to the disc. The important thing is the heat transfer from the fluid to the discs. Actually I implemented a model with 2 solid (discs) and a fluid domain (fluid) in between. The domains are connected by fluid-solid-interfaces (GGI). The boundary surface between fluid and solid is wall with a rotational speed. Because the fluid has a inhomogeneous haet distribution, to solve the Problem accurate, a rotation of the solid discs is needed to get the correct heat distribution on the discs. The problem is that i do not know how to realize a rotation of the solid discs. It would be great, if somebody has some detailed information to solve the problem. Thank you so far, Joe |
April 23, 2009, 18:40 |
Rep Power: 143 |
Do what want to solve the temperature distribution in the disks? In that case you need a CHT simulation (conjugate heat transfer, ie a fluid domain and a solid domain) where the solid domain also rotates. I think you need V12 for this, I don't think it is supported in V11. Ask your CFX support people for the V12 beta. Glenn Horrocks |
April 27, 2009, 06:58 |
Rep Power: 17 |
I contacted the support and it is also possible to "Enable Beta Features" in Advanced CFD.
Edit -> Options -> CFX-Pre --> Enable Beta Features. It is now possible to use beta feauters including rotation of solid domains. Thank you for your information. |
domain, motion, rotation, solid |
UDF for solid body rotation | araz | Fluent UDF and Scheme Programming | 1 | January 13, 2016 02:46 |
Multiple Solid Domains - Interfaces | Scott | CFX | 8 | July 31, 2008 15:20 |
Freely solid rotation inside a fluid | Juan Maria | CFX | 0 | April 10, 2008 07:59 |
rotation of solid domain | manohar | FLUENT | 1 | July 22, 2005 13:34 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
