partially filled tank under acceleration
Old   June 8, 2009, 20:40
Default partially filled tank under acceleration
ETS Motorsport
Jean-Gabriel is on a distinguished road
Hi, I'm not used to ansys CFX or Fluent but can someone help me with the next question.
As part of formula SAE team from ETS motorsport, we had an issue with the fuel tank in high speed cornering (1.5 to 1.8 g's) has a consequence the engine shut.
So, I would like to do CFD analysis to optimize the amount of fuel needed to ensure engine runnng under g's.
"How can i simulate a solid tank partially filled with fuel and air(under pressure 45PSI) in a acceleration state"
I don't need any animation only steady state result.
Thanks a lot as a new member of this forum I will post again for further information on CFX.
Jean-Gabriel is offline   Reply With Quote
Old   June 9, 2009, 04:07
Rui
Rui's Avatar
Rui Igreja
Rui is on a distinguished road
That's a hydrostatic problem, isn't it?
Rui
Rui is offline   Reply With Quote
Old   June 9, 2009, 06:57
stumpy is on a distinguished road
I would just use a rotating reference frame - so you're simulating the car going around a circle. The rotation rate and the distance of the rotation axis from the tank will determine the g-force applied. Since both air and fuel are present it will be a free surface problem - see the "flow over bump" tutorial for how to set this up. make sure you use "Air ideal gas" as the material for the air phase, since the air will compress at 45 psi. Use a Reference Pressure of 45 psi. Use expressions to set the initial conditions for air/fuel volume fraction.
Mike
stumpy is offline   Reply With Quote
Old   June 9, 2009, 07:20
Rui
Rui's Avatar
Rui Igreja
Still . . .
Rui
Old   June 9, 2009, 08:07
Yes Rui, if all he wants is the steady state result then I can't see why you need CFD at all - just draw a plane which is perpendicular to the acceleration vector enclosing the volume of fuel. No CFD needed. See, I just saved you a few weeks worth of simulation.
But on the other hand there is NO WAY that a steady state surface will represent anything like what fuel in a tank in a race car wizzing around at 1.5g's is going to do. Here's a little experiment - fill a glass with water, give it a little push from the side and what happens? The surface rocks back and forth, maybe it spills over the top, maybe the flow forms breaking waves. You are kidding yourself if you think you can get anything meaningful with a steady state simulation.
If you are looking for a challenging CFD topic then do a transient CFD analysis of fuel sloshing in a tank. Unless you are an experienced CFD person with free surface modelling experience I guarantee it will take you several months before you get anything close to reality.
If you are looking to help your FSAE team design a better fuel tank than forget CFD and go to the library and look for some fuel tank design textbooks. You won't need CFD to come up with a better design.
Old   June 9, 2009, 08:55
Default Thanks
ETS Motorsport
Thanks guys, the only reason why I would like to use the CFD simulation was because of the complexe geometry of the fuel tank. But, I don't have a month to spend in CFD simulation and so i will try theoritical calculation over a representative simpler geometry.
thanks again for the help
Old   June 9, 2009, 18:29
Complex geometry in the fuel tank? Sounds easy for a solid modelling package.
acceleration, formula, partially filled, steady state, tank
partially filled tank, evaporation at liq-vap. prasanth FLUENT 5 July 24, 2013 17:12
partially filled fuel tank Deniz Boyacı FLUENT 0 March 9, 2009 02:03
Settling tank John Grimm FLUENT 1 March 20, 2005 08:20
tank leakage H FLUENT 0 October 4, 2004 20:28
injection of fuel into tank filled with fuel mujahid FLUENT 1 February 19, 2004 06:36
