July 24, 2009, 08:58 |
wind turbine simulation
tato
Rep Power: 16 |
I try to make wind turbine simulation using CFX. But I have some question:1) What is the good turbulence model for this simulation? 2) How to calculate power from my simulation? 3) My boundary condition for my blade is wall, but I don't know exactly it is smooth wall or roughness wall? 4) How far accurate that simulate wind turbine using CFX? 5) What I can get from CFX in this simulation ( I know only pressure distribution and streamline visualization). Thank you all
July 25, 2009, 06:48 |
Rep Power: 143 |
1) SST is a good general purpose aerofoil turbulence model. I have no idea how well it handles the atmospheric boundary layer.
2) Use the CFD-Post turbomachinery macro and read the documentation. 3) So, what is your question here? 4) Are you asking how accurate is CFD modelling of wind turbines? I have no experience in the area but suspect if you are careful and correctly model the atmospheric conditions, geometry (including distortions), turbulence transition etc it should be very accurate. Of course you might need a supercomputer to run it. How accurate a simulation can be done using the resources you have available is a more difficult question. 5) From an accurate simulation you can get everything aerodynamic there is to know about the flow field. See answer 4. Glenn Horrocks |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Problem with interface in a wind turbine simulation | be_inspired | FLUENT | 2 | March 7, 2011 23:46 |
Angular velocity in wind turbine simulation | vanni | Main CFD Forum | 1 | May 18, 2009 11:03 |
Wind turbine simulation | Saturn | FLUENT | 1 | June 16, 2006 02:12 |
Wind turbine simulation | Saturn | Main CFD Forum | 1 | June 12, 2006 03:57 |
