Help with Fortran Compiler
Old   August 4, 2009, 08:59
Default Help with Fortran Compiler
fabio
fabioacfoz is on a distinguished road
Hello, i found some topics about this subject but none worked for my case. Im doing the Air Conditioning tutorial and it asks to compile a fortran routine TStat_Control.F by the command:
! system ("cfx5mkext TStat_Control.F") == 0 or die "cfx5mkext failed";
But when i put this on the editor it gives the message
ERROR
CCL parser failed with message:
Perl Syntax errors detected:
cfx5mkext failed at (eval 1320) line 1.
I instaled about 10 compilers os fortran, so i imagine it is not that. Maybe some modification on the rotine? Can anyone help me???
fabioacfoz is offline   Reply With Quote
Old   August 4, 2009, 19:16
fabio
In fact, when i try to compile TStat_Control.F in Intel Visual Fortran Compiler 11.1 it encouter errors. Do anyone have the library files there??
Old   August 17, 2010, 10:04
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Did you manage to sort this out? If so, how did you do it? I am trying to do this example myself, but get the same error. Complete beginner when it comes to fortran so any help would be appreciated.
Or if anyone else knows, please feel free to chime in. Im on a linux machine
jrunsten is offline   Reply With Quote
Old   March 22, 2011, 07:51
Default warning #13380: Compiler configuration problem encountered. Compiler cannot load imf
dipesh
dipesh.patle is on a distinguished road
I am working on the interfacing of fortran with aspen plus software.
while compiling from aspen plus simulation engine I am getting following error;
"warning #13380: Compiler configuration problem encountered. Compiler cannot load imf dispatching library."
I am using 'Intel Visual Fortran Compiler 10.1.024' and Aspen Plus 2006.5
Could you please guide me on this?
Thank you in advance.
dipesh.patle is offline   Reply With Quote
Old   June 15, 2013, 19:28
Boyd B.
olugabsy is on a distinguished road
Hi,did you eventually succeed in your request?If you did,kindly help out on the way how you evetually went through,as i have a similar problem now as yours.
olugabsy is offline   Reply With Quote
Intel Fortran Compiler & Tutorial 17 Young CFX 1 March 30, 2011 01:39
Fortran Compiler and example Young CFX 1 March 22, 2011 22:26
Fortran compiler Erik Siemens 2 November 28, 2008 20:05
Which Fortran compiler? Tony Siemens 6 November 19, 2005 05:44
Fortran compiler Arnab Siemens 5 September 14, 2004 03:59
