Results analyse -free surface model
Old   February 2, 2010, 10:36
Default Results analyse -free surface model
antonio is on a distinguished road
Hi all.
I`m following the free-surface tutorial. As my domain has a geometry that has translational periodicity I have used a domain interface (with a pressure change of -1.044664 Pa). The dimensions of the domain are 49.267 mm (longitudinal direction) 160mm (height of the domain) and 800 (it`s the width of the channel). I have a rough bed (with an inclination of 8.9*10^-4)formed by the contour of triangles (with an height of 4.61 mm). The initial expressions that I have used are the same as the tutorial (as I want to have an uniform regime I set a UpH and DownH to 0.12 m) and I have used the same boundaries presented in the tutorial (inlet, outlet opening and wall). I have not used a symmetry boundary because the mesh is not symmetric. Observing the results in CFD-Post I have the feeling that I don`t have an uniform regime. When I create an isosurface (water volume fraction of 0.06) the free surface is very irregular and the green line that should appear is not continuous. I also have water for higher water volume fractions...Should I create a larger domain to have an uniform regime?
Best Regards
antonio is offline   Reply With Quote
Old   February 2, 2010, 17:02
Can you post some images of you geometry, mesh and the results you are getting?
Old   February 3, 2010, 05:23
Good morning all
Dear Ghorrocks. Sure I can post some images. Can you explain me how to do that? I`m having some difficulties.
Regards
Old   February 4, 2010, 05:04
My guess is the button labelled "Insert Image" will do it. But I am just guessing there.
Old   February 5, 2010, 12:35
Hi there.
I have already did what you mentioned but I did not have success.
However, I think my main problem is solved. I have created a monitor point and I have seen the water volume fraction evaluation along the simulation and it seems that this variable is constant when I achieve a significant number of iterations so I suppose I have an uniform regime...
Best Regards
MULTIPHASE - FREE SURFACE & MIXTURE MODEL Aris FLUENT 3 April 28, 2009 11:46
VOF and Free surface model...are they same? Kushagra CFX 1 November 14, 2008 12:36
Boundary condition of free surface model Tony FLUENT 3 September 27, 2004 13:48
free surface display novice Siemens 5 August 4, 2004 01:07
sphere in a free surface (thin film)flow Vasu Veerapaneni Main CFD Forum 0 September 15, 1998 17:32
