Very Strange Error: "Error reading number of domains"
Like Tree9Likes
Old   May 14, 2015, 02:23
Lorenzo Mazzei
Mazze[ITA] is on a distinguished road
CFD-Post needs information about the mesh: try to load the .def file concurrently with the other files.
Mazze[ITA] is offline   Reply With Quote
Old   May 14, 2015, 05:29
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
Dear Opaque, and Lorenzo,
I've tried what you two supposed but it didn't work!!
I ran the simulation for just 2 time steps and then save the files. after that I add the .trn files into the time step selector, so I now have access to my data.
thanks for the reply.
Regards,
Mostafa
Mazze[ITA] and morelix like this.
adambarfi is offline   Reply With Quote
Old   November 9, 2015, 10:25
Desti is on a distinguished road
Thanks a lot.
The hint with "include mesh" worked =)
Desti is offline   Reply With Quote
Old   August 23, 2016, 13:06
Red face
  #24
mehaque101's Avatar
Haq
mehaque101 is on a distinguished road
Originally Posted by adambarfi View Post
Hi everybody,
I have the same problem.
I forgot to check the include mesh option and then after about 2 weeks solving my case, I cannot access the data!
I'm trying to simulate a turbulent flow over a bluff body using by LES and it's transient.
I've tried opening the mesh separately and then importing the .trn files but it didn't work and I still have the 'Error Reading Number of Domains (G/NZN)' error.
anybody knows how can I solve this problem? I didn't enough time to re-solve my case.
Regards,
Mostafa
Dear
I have the similar problem, and I would like to know,
where did you forget "the include mesh" option.
Thanks.
mehaque101 is offline   Reply With Quote
Old   March 13, 2017, 07:24
Solonariwan Tofusin
stormrider is on a distinguished road
Hi all! I know the thread has been dead for a while, but it is the first result I found when searching for this error, so I think it's worth it to post the solution I found to it.
1- You can include the mesh when setting up your trn results. (if you plan to have a lot of .trn saved this will take a lot of disk space)
2- If you have .trn without mesh and you get the error: you can load a completed run using the same mesh as your .trn, go in the time step selector of CFD Post and add a timestep choosing the .trn file you want to postprocess. Doing so you can also choose .trn withou mesh from simulations that did not generate any .bak or .res file. (you can create a result file also by starting a simulation with 1 iteration)
I hope this will help and save some time to the next person stumbling on this topic!
S.T.
bamaoli and Mojo like this.
stormrider is offline   Reply With Quote
Old   December 31, 2020, 02:51
Vivek MJ
vivjk94 is on a distinguished road
Ticking input mesh files in output control did it for me.
vivjk94 is offline   Reply With Quote
decomposePar no field transfert Jeanp OpenFOAM Pre-Processing 3 June 18, 2022 12:01
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 22:40
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
