January 24, 2010, 20:39 |
FSI Thermal energy non-convergence...
Rep Power: 16 |
Dear all,
I performed an FSI, and it resulted to a Thermal energy non-convergence, T-Energy did not converged to my required residual. on the T-Energy plot, it was going towards convergence until after the 153rd iteration and it remained in a state of oscillation with lots of high frequency peaks. how should i go about diagnosing my results/setup please? look forward to hear of any comments/suggestions. Thanks!
Thank you for your kind attention. Kind regards, mactech001 Currently using: ANSYS v13 |
January 26, 2010, 16:15 |
Rep Power: 143 |
If you turn FSI off does it converge quickly?
January 26, 2010, 19:58 |
Rep Power: 16 |
Hi Glenn, thanks for your reply.
i would like to perform a fluid-solid heat transfer using FSI. if i were to turn FSI off, will it not calculate the heat transfer properly please?
January 26, 2010, 20:07 |
Rep Power: 143 |
CFX can do fluid-solid heat transfer itself with no need for FSI. Why are you using ANSYS for the heat transfer? What is stopping you doing everything in CFX?
January 26, 2010, 20:58 |
Rep Power: 16 |
So sorry Glenn, i'm confused...
i am calculating heat transfer totally in CFX..... the solid model and fluid model are in CFX. i've created the Fluid Solid Interface sides in CFX...... are you asking me to delete the Fluid Solid Interface sides in CFX and CFX will still calculate heat transfer for me??? what do you mean by turning off FSI please?
January 26, 2010, 21:02 |
Rep Power: 143 |
OK, in that case you are not doing FSI, you are doing a conjugate heat transfer simulation or CHT.
Can you describe what you are modelling? |
January 26, 2010, 21:26 |
Rep Power: 16 |
i'm modeling heat transfer from a housing (cylindrical in shape) which has coolant ports, one inlet & one outlet. heat source is heat flux from the inner surface of the housing. i would like to calculate the pressure difference of the cooling channel design, heat taken away by coolant and film coefficient.
January 26, 2010, 21:55 |
Rep Power: 143 |
Is the fluid coupled to the heat transfer? If so, how? When you run the fluid by itself does it converge?
January 26, 2010, 22:06 |
#9 |
Rep Power: 16 |
I mainly followed most of the setup in the CHT tutorial...
Both fluid & solid model Heat transfer setting is Thermal Energy. fluid solid interface mesh connectio method is GGI Fluid has finer mesh than solid. All other RMS residuals (P-Mass,U-Mom,V-Mom,H-Energy,E-Diss.K,K-TurbKE) converged to my set residual target, EXCEPT for the T-Energy.
January 26, 2010, 22:15 |
#10 |
Rep Power: 143 |
Have you worked through the issues discussed here:
http://www.cfd-online.com/Wiki/Ansys...gence_criteria Are you steady state or transient? With CHT a number of other issues come up. The main one usually is the fact the solid time scales are much slower than fluid time scales, which results in the fluids converging normally but the solid converging very slowly. If you are doing a steady state run the fix for this is to use the solid timescale factor to run the solid at a faster rate to the fluid. If transient you just have to be patient and wait for it to finish! But you are not getting slow convergence you are getting a failure to converge. This may still be fixed using solid timescale factors, but can also be caused by many other factors. |
January 26, 2010, 23:27 |
#11 |
Rep Power: 16 |
i'm performing a steady-state analysis.
i've set the Solid Timescale Control > Solid Timescale = 2[s]. for the fluid Timescale, it is set to Auto Timescale. From the results file's Timescale information table, the Fluild timescale has always been 9.7e-2
January 26, 2010, 23:45 |
#12 |
Rep Power: 143 |
Try making the solid timescale 100x larger and as a second test the same as the fluid time scale.
January 27, 2010, 01:12 |
#13 |
Rep Power: 16 |
Hi Glenn,
For Steady-state, one of the fix mentioned above is to use the solid timescale factor. To run the solid at faster rate, should i increase the solid timescale factor? is it the same effect as reducing the solid timescale?? i'm also attaching a picture file of the T-Energy convergence graph. It is not converging slower than the fluid, but not converging at all......
January 27, 2010, 15:49 |
#14 |
Rep Power: 143 |
The solid timescale factor is the factor by which the solid time scale is larger than the fluid timescale. 100 means the solid timescale is 100 times the fluid timescale.
Have you looked at the residuals in CFD-Post? That will tell you where the problem residuals lie. You will have to put the residuals in the output file. Can you post the CCL of your simulation? |
January 28, 2010, 14:45 |
#15 |
Rep Power: 21 |
Turn on double-precision too.
January 28, 2010, 23:58 |
#16 |
Rep Power: 16 |
To Glenn:
i didn't put the residual into the output file to view it in CFX-Post...... could i edit the result file and export the residual or should i redo the calculation again with the output setting to include residuals please? To stumpy: where do i turn-on the double precision please? does this require me to redo the calculation please? attached also is the CCL file.
January 29, 2010, 16:47 |
#17 |
Rep Power: 21 |
See the doc for double precision. Also, if you have a matching mesh at the fluid-solid domain interface, change the interface so the mesh connection method is GGI. If it's non-matching it will be GGI in any case.
Regards |
January 30, 2010, 05:45 |
#18 |
Rep Power: 143 |
You will need to rerun to put the residuals in the output file. Don't forget this just needs to be a restart, so no need to go right from initial conditions.
Stumpy's suggests are also worth trying. Have you tried double precision and forcing use of a GGI? |
February 2, 2010, 22:31 |
#19 |
Rep Power: 16 |
Hi guys,
I've forced to use GGI meshing from the start. but not double precision....... i still can't find how to set this double precision in CFX-Pre... any directions please?
February 3, 2010, 03:58 |
#20 |
Rep Power: 143 |
In V11 you need to select double precision in solver manager or the command line. In V12 you can select it in CFX-Pre.
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Diff bet total energy & thermal energy model?? | vijeshjoshi23 | CFX | 5 | October 9, 2009 10:31 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
SIMPLE and energy equation convergence | Fabio | Main CFD Forum | 0 | June 1, 2007 06:06 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
