February 19, 2010, 10:42 |
Convergence criteria
Steven Tay
Rep Power: 16 |
Is there any way to set different convergence criteria for momentum & mass and heat transfer for CFX? Currently, there is only one setting for all. I know that Fluent is able to do it but not sure whether CFX is able to do that too. Appreciate if there are anyone that are able to advise me. Many thanks! |
February 19, 2010, 11:20 |
prout
Rep Power: 16 |
Right click on "Solver control" in CFX-Pre > Edit > Equation Class Settings tab!
February 19, 2010, 11:47 |
Steven Tay
Rep Power: 16 |
Hi Zboud,
Many thanks for your fast respond! I will try it out. |
February 20, 2010, 10:40 |
Steven Tay
Rep Power: 16 |
Hi Zboud,
Under the basic setting of solver control, there is a convergence criteria setting for RMS. By setting the RMS value, it will set the convergnce criteria for energy, momentum and so on.. I wanted to set the convergence critegia of individual item like, thermal energy - 1e-6, momentum - 1e-3... Is that possible? Need your advice. Thanks. |
February 20, 2010, 12:39 |
az prout said check the Equation Class Settings tab you can do that.
February 21, 2010, 02:46 |
Steven Tay
Rep Power: 16 |
I am running transient and the convergence control does not appear at the equation class setting. I realised that the convergence control for individual item will only appear when the run is set to steady state. Does that mean that I will not be able to set individual convergence criteria if the run is set to transient? |
May 14, 2010, 12:48 |
Rep Power: 17 |
In Pre, right click on Solver Control and select Edit. Under Convergence Criteria, check Conservation Target and set a value. I understand that 0.01 is a pretty good value to use.
convergence criteria | iuaniu | CFX | 3 | September 24, 2009 19:20 |
Convergence criteria | PrandtlGlawert | Main CFD Forum | 1 | August 13, 2009 17:13 |
star-ccm+ convergence criteria | star | Siemens | 2 | January 14, 2009 04:57 |
Convergence Criteria | edwin | FLUENT | 1 | February 14, 2008 19:24 |
CAVITATION (convergence criteria & discretization) | ROOZBEH | FLUENT | 1 | October 6, 2003 09:32 |
