Error cfx #001100279
Old   March 12, 2013, 20:22
Default Error cfx #001100279
Talles Caio
TallesC is on a distinguished road
e need help for this problem below:
| ****** Notice ****** |
| Newtons method failed to converge in 100 iterations. This |
| occurred while computing the following variable: |
| Variable Name : Temperature |
| Location Name : serpentina |
| Mesh location : VERTICES |
| Mesh entity : |
| Last 3 Changes : 3.08842E+23 3.76202E+23 4.58254E+23 |
| Tolerance : 1.0000E-02 |
| The Newton iteration was diverging. The solver will continue |
| with the variable field as it was on the final iteration. If |
| this situation continues you might try decreasing the Newton |
| iteration under relaxation factor. This can be changed by |
| setting one of the following parameters: |
| Temperature : "Constitutive Relation Under Relaxation" |
| Pressure : "Newton Pressure Under Relaxation" |
| for your mixture using the definition file editor. |
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Floating point exception: Overflow
TallesC is offline   Reply With Quote
Old   March 13, 2013, 06:01
The floating point overflow is a FAQ: http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
But to get it like this you probably have some strange material properties. Can you explain what you are doing?
ERROR #001100279 has occurred in subroutine ErrAction. wangy1767 CFX 36 July 25, 2020 06:09
ERROR #001100279 has occurred in subroutine ErrAction. smnaryal CFX 11 December 20, 2017 16:32
What is ERROR #001100279 and how do I fix it? siw CFX 1 May 30, 2017 14:02
Error #001100279 bharath CFX 9 March 25, 2015 05:31
ERROR #001100279 has occurred in subroutine ErrAction. P9408 CFX 1 August 19, 2009 07:56
